BoRRoZ
June 27, 2016, 9:18am
14
[18 - barometric pressure / altitude]
This device is really easy to use, if your thinking of using it with an Arduino then you need to check out our BMP180 arduino tutorial. Using a sensor as capable as the BMP180 you can achieve accurary of 1m, with noise of only 17cm in ultra high...
BoRRoZ
June 30, 2016, 7:05am
19
[4 - door / window contacts]
robust switches
reed switch
BoRRoZ
July 1, 2016, 7:54pm
20
BoRRoZ
July 10, 2016, 7:33am
22
sensors of the near future
Topic 16 - Air Quality with the MQ-Series of gas detectors
http://www.gearbest.com/sensors/pp_261780.html
BoRRoZ
July 11, 2016, 5:08pm
24
in Holland oa hier en hier verkrijgbaar
eBreathalyzer use case
Rob65
July 12, 2016, 4:30pm
25
also available from TinyTronics . I just picked up some stuff in EIndhoven today: “Yes - LoRa is becoming a big hit - I am also looking at some LoRa modules to sell.”
I previously bought a lot of stuff directly from China, but after having some problems with faulty stuff, I now buy most of my stuff from this shop.
[ xx - Lightning Sensor ]
BoRRoZ
July 14, 2016, 12:30pm
28
I really love this thread! We put it on our Twitter:
BoRRoZ
July 14, 2016, 7:39pm
30
[6 - motion detection DOPPLER]
‘china’ doppler modules - very sensitive, detect movement through walls and doors !
It uses Doppler radar technology. microwave sensors using planar antenna and receiving for echo. Trigger: Repeat Trigger (default);. Widely used in lighting situations,anti-theft alarm situations. sensor distance, reliability, wide angle sensor. |...
this type is good
BoRRoZ
July 16, 2016, 10:08am
32
[42 - temperature switch (thermostat)]
paulb
July 17, 2016, 8:59pm
33
[10 - Current]
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313.TR0.TRC0.H0.Xacs712.TRS0&_nkw=acs712&_sacat=0
Project page:
Usually, if I buy a high power electric appliance, I like to double check it power consumption either with a Kill-a-watt when possible, and when not, e.g.
